FPGA module evaluation and Xilinx tools?
I'm currently using an evaluation version of LabVIEW 2013 and the FPGA module.  When I try to build my FPGA target, I get as far as selecting the compile server.  There, I am unable to use the local compile server because "The Xilinx 14.4 tools are not installed."
I had been under the impression that the Xilinx tools came with the FPGA module.  In the FPGA module install, I don't even have the option to select to install Xilinx...  What's going on here?  Is this happening because I'm only using an evaluation version rather than a registered version?  Or did I miss something?  Do I really need to get the Xilinx tools separately?
Thanks!
Sara
(3,164 Views)
Accepted by Sara_J
Howdy Sara,
It is indeed a separate installer. Give this a go! Cat Happy
NI LabVIEW 2013 FPGA Module Xilinx Tools 14.4
http://www.ni.com/download/labview-fpga-module-2013/4248/en/
Tim A.
(3,130 Views)
Thanks.  Are the Xilinx tools a separate purchase, then, or are they included in the price of the FPGA module?
(3,047 Views)
They are not a seperate purchase.  The install is quite large so you maybe downloading for a while.  When you get the developer suite it actually comes on a seperate DVD.
(3,038 Views)
Ah.  Thanks for the clarification!
(3,033 Views)
