Command Line Arguments to VI Without Building EXE
I am following this guide: Passing Command Line Arguments to a LabVIEW Executable
I want to pass command line arguments in Windows to LabVIEW without building my project into a EXE.  I just want to pass them to a VI which is set to Run When Opened.
This is my LabVIEW code:
However when I call my VI using the command line, I do not see my user-arguments:
"C:\Program Files\National Instruments\LabVIEW 2009\LabVIEW.exe" "C:\Desktop\LabVIEW Code\test.vi" -- test arg1 arg2
The above call only yields "LabVIEW" as the first command line arguement.  I don't see "test", "arg1", or "arg2" in the Command Line Arguments array.
If someone helped you out, please select their post as the solution and/or give them Kudos!
Message 1 of 9
(5,861 Views)
Hi Happy
There's a working example in C:\Program Files\National Instruments\LabVIEW 2010\examples\viserver\cmdline.llb.
Not sure if it's in LV 2009 ?
Good luck !
Message 2 of 9
(5,825 Views)
@NeilR wrote:
Hi Happy
Good luck !
This example file uses the same approach as above, however it also does not work:
"C:\Program Files\National Instruments\LabVIEW 2009\LabVIEW.exe" "C:\Program Files\National Instruments\LabVIEW 2009\examples\viserver\cmdline.llb\CommandLine.vi" -- /number:4.000000
Output:
Message 3 of 9
(5,820 Views)
Check into the examples for Asynchronous Call By reference.  Essentially you need to open a vi server reference to the vi with the right flags set.  the help on open vi server reference will explain the flags.
"Should be" isn't "Is" -Jay
Message 4 of 9
(5,808 Views)
Would you be able to create an example?  I found this: Asynchronously Calling VIs but it seems to only address running a subVI in an asynchronous manner.  It doesn't explain command line arguements passed when the VI first runs.
Message 5 of 9
(5,796 Views)
Accepted by topic author MrHappyAsthma
Hmmm ... that's disappointing. I've just tried it with LV 8.5 and it's fine with that too.
I've been running these under XP SP3.
I assume you completely closed Labview before running the command line ?
Message 6 of 9
(5,788 Views)
Mr. Happy
I could respond with a volume or a simple example.
What do you want to accomplish?  What have you tried?  And, I know the help file can make you gyrate unexpectedly.
Message 7 of 9
(5,785 Views)
I am using Windows 7 and LabVIEW 2009.
I do, indeed, close LabVIEW completely before trying to run that example.
All I need is a way to execute my VI and pass it some custom parameters using the double hyphen (--).
EDIT:
I finally got it to work.  The "closing out completely" did the trick.  For some reason a LabVIEW process was still running in the background...  But I force closed it with Task Manager and now it works!
Message 8 of 9
(5,776 Views)
Yep ... it should be easy. I sense your frustration.
Just tried the same example with LV 2012 running under Windows 7.
Same result. Fine. Smiley Frustrated
EDIT: Just seen your edit. Good news !!
Message 9 of 9
(5,764 Views)
