06-30-2013 01:31 AM
I'm trying to implement the LabVIEW FPGA Waveform Acquisition and Logging on cRIO template in LV2012sp1 onto a cRIO-9002.
So I'm stumped as to how to proceed and the documentation guidelines do not address this issue at all. I would greatly appreciate if someone could point me in the right direction.
07-01-2013 11:55 AM
Hi Greg,
Have you tried reformatting the RT controller? This might work since we are dealing with the SVE not being recognized. There is also a possibility that since your NI-9002 is an older device the drivers are having compadibility issues. Let me know if the reformating helps.
07-01-2013 06:16 PM
Thanks Ryan,
I reformatted the RT and reinstalled software to the cRIO. Unlike previously, this time I specifically identified add-in components, including the Network Variable Engine and the Variable Client Support (which the first pane in Add/Remove Software seems to indicate is already on the RT). So the installation is completed... Now these components (Network Variable Engine & Variable Client Support) are listed in MAX cRIO/Software (unlike previously). So this is an improvement. The Shared Variable deployment is now successful along with many other componets, but deployment now hangs on:
Failed to load shared library lvanlys.*:DotProduct_head:C. Ensure that the library is present on the RT target.
The process of identifying the specific needed software components to load, out of a myriad of possibilities, is indeed not clear at this point. Perhaps this is documented somewhere in the template lvproj that I'm trying to implement...
07-02-2013 10:20 AM - edited 07-02-2013 10:20 AM
Hi Greg,
Can you send a screenshot of the message? We have seen a similar issue in the past and it usually just requires a software repair. Try doing a repair on LabVIEW and installing NI-RIO 12.1. I just want to see if this changes the behavior at all. Thank you for your patience as we figure this out.
07-02-2013 11:55 AM
Here's the deploy:
Initializing...
Calculating dependencies...
Checking items for conflicts. This operation could take a while...
Preparing items for download. This operation could take a while...
Deploying Shared Variables.lvlib
Deploying NI_Real-Time Target Support.lvlib
Deploying Message Queue.lvlib
Deploying NI_AALPro.lvlib
Deploying NI_AALBase.lvlib
Deploying NI_PackedLibraryUtility.lvlib
Deploying NI_FileType.lvlib
Deploying nisyscfg.lvlib
Deploying Shared Variables.lvlib:Actual Loop Period\\192.168.0.2\Shared Variables\Actual Loop Period deployed.
Deploying Shared Variables.lvlib:Buffer Backlog\\192.168.0.2\Shared Variables\Buffer Backlog deployed.
Deploying Shared Variables.lvlib:Contiguous Memory\\192.168.0.2\Shared Variables\Contiguous Memory deployed.
Deploying Shared Variables.lvlib:CPU Usage\\192.168.0.2\Shared Variables\CPU Usage deployed.
Deploying Shared Variables.lvlib:Drive Space\\192.168.0.2\Shared Variables\Drive Space deployed.
Deploying Shared Variables.lvlib:Number of Data Files\\192.168.0.2\Shared Variables\Number of Data Files deployed.
Deploying Shared Variables.lvlib:System Time\\192.168.0.2\Shared Variables\System Time deployed.
Deploying waveform01.lvproj
Deploying Hank(successfully deployed target settings)
Deploying NI_PackedLibraryUtility.lvlib:Get Exported File List.vi (8.90 K)
Deploying Clear Errors.vi (3.99 K)
Deploying DialogTypeEnum.ctl (2.00 K)
Deploying FindEmptyElement.vi (6.87 K)
Deploying Error Cluster From Error Code.vi (37.48 K)
Deploying niLvFpga_Run_Dynamic.vi (11.47 K)
Deploying DialogType.ctl (2.00 K)
Deploying Watchdog status enum.ctl (2.00 K)
Deploying NI_Real-Time Target Support.lvlib:RT Get Number of CPUs.vi (4.29 K)
Deploying TagReturnType.ctl (2.00 K)
Deploying Open File+.vi (21.16 K)
Deploying NI_AALBase.lvlib:Real Dot Product.viNI_AALBase.lvlib:Real Dot Product.vi loaded with errors on the target and was closed.
LabVIEW: Failed to load shared library lvanlys.*:DotProduct_head:C. Ensure that the library is present on the RT target. Use MAX to install NI software or FTP to transfer custom libraries to the RT target.
Deployment completed with errors
07-03-2013 10:52 AM
Hi Greg,
Were you abe to attempt and repair LabVIEW and update NI-RIO to 12.1? By the way, which version of LabVIEW are you using?
07-03-2013 12:46 PM
After proceeding through the RT deployment errors and then adding the missing software components one by one, the deployment now completes without errors. When I run the UI Main.vi, connection to the controller fails:
UI Error -314004 - Create Network Stream Writer Endpoint in UI - Initiate Connection.vi->UI Main.vi
In UI Main.vi the "Controller Address" must be specified. I'm providing the IP address, but it does not seem to matter what address I use, or even whether the cRIO is even on...
07-08-2013 12:20 PM
Did you try the repairs like I suggested?
