FPGA Max and Min
Attached is a simple code I am trying to do in FPGA.  I am sending a signal to my 9215.  The wave can be sine, triangular, etc....doesn't matter nor does the freq.  What I need is the Max and Min of the signal at each cycle.  The problem with the code is that I get the max and min of each cycle, but when the 0 crossing occurs, the max and min of that previous cycle are reset to 0 rather then just being held until the new max and min of the cycle found.  I would like for the max and min to be held until the new max/min is found, then replaced.  I know why this is occuring, however, I am having difficulty trying to solve this solution.  I tried another case structure, and it does the same thing.  I feel this is a fairly simple problem to be solved and I am probably overlooking the obvious answer.  All help appreciated as well as suggestions.
guilio
(3,905 Views)
Any reason you don't use the Min Max function (in the comparation palette)?
Avoid cases at all costs on your FPGA. Use a case selector instead.
Wiebe.
(3,876 Views)
I didn't use the max and min from the comparison pallet because I need this to get the max and min of each cycle and there wasn't a way for me to reset the max and min to 0.  Also when just plugging in the single input number, I get the same thing of it counting each input rather then just holding the max and min.
guilio
(3,862 Views)
Guilio,
You can still use the min max for the inner case...
If you want to hold the maximum, until a new cycle has a new maximum, you'll need another feedback node. I prefer shift registers. See attached picture.
Wiebe.
(3,858 Views)
