FPGA: 2-D arrays supported?
I'm getting an error in an FPGA VI when editing the VI (broken run button): "Maximum number of array dimensions exceeded for target"  The array is 8x16 boolean.  Doesn't the target support 2-D arrays?  My target is cRIO-9102.  I tried to make the control smaller, too, but without success.
Rob
Rob
Message 1 of 10
(7,385 Views)
I meant to include this image of the VI too
Rob
Message 2 of 10
(7,376 Views)
Accepted by topic author robdevyogi
1-D arrays only using LV FPGA, so 2-D arrays is not supported. Read more about using clusters and arrays here:
http://zone.ni.com/devzone/cda/tut/p/id/4520
Message Edited by Jimmie A. on 04-14-2008 07:58 AM
Jimmie Adolph
Systems Engineering Manager, National Instruments Northern European Region
Message 3 of 10
(7,353 Views)
Hi robdevyogi,
Jimmie is correct that only 1D arrays are supported with LabVIEW FPGA. There is a great page on the LabVIEW help that lists the array functions that are supported by FPGA. I hope this helps!
Carla
Applications Engineer
Message 4 of 10
(7,325 Views)
Thanks, yes, it wasn't obvious to me that 2-D wasn't available for FPGA!  I guess those functions would take up a lot of SLICEs...
Since I was working with boolean I was able to work around it by creating an array of U8 or U16 and then converting the number to a boolean array inside the for loop.
Rob
Rob
Message 5 of 10
(7,282 Views)
Hi, I am experiencing a similar problem with my NI PXI 7833 and fpga module. I need to burn a code which inherently contains boolean 2D arrays in it. I am looking for effective ways to express a 2d array as a 1d array... if you have succeded in doing so kindly reply... your help shall be greatly appreciated.
cheers
Sid
Message Edited by anderson1988 on 12-16-2008 02:09 AM
Message 6 of 10
(7,065 Views)
Use the functions for converting a boolean array to a number (e.g. a U16) then store values in an array of U16.  When reading, you index the array, you get a U16 value, then convert it to a boolean array and index the individual boolean value if necessary.
Message Edited by robdevyogi on 12-16-2008 01:11 PM
Rob
Message 7 of 10
(7,042 Views)
This process is called interleaving, there is a VI in the array palette to do it.  The reverse process is called decimating, and there is also a VI to do that.
Jeremy_B
Message 8 of 10
(7,037 Views)
cheers
Sid
If you want to do it mathematically (I did this in the past in BASIC - yes, I've been around that long), then store everything in a one-dimensional array and calculate the index into that array.
 Example: if you have two dimensions (X,Y) and the Y dimension is of a maximum size of Z, then the index into the one dimensional array would be X * Z + Y.
This should work well with LabVIEW since it starts all indices at 0.
I hope this helps and that you can get it working.
     Rob
Message 9 of 10
(7,026 Views)
This is certainly a good option.
However, let us say that you want to support the following operations:
a) Read/Write an entire row in one clock cycle
b) Read/Write an entire column in one clock cycle
-- in this case, the design wouldn't work.
Message 10 of 10
(5,408 Views)
