Extract Data between cursors
Hello, here I have an XY graph that displays X values and 3 different Y values for each X. I am able to graph the matrix just fine, but now I am needing to insert two different cursors, and want the program to be able to take the information in between those two cursors and write it to a different file.
(4,131 Views)
You can use "cursor -> Position -> X" property
(4,110 Views)
What would the flat sequence consist of? I'm not entirely sure what to do from that point on.
(4,103 Views)
You need to find in the data array the elements (indexes) that lie between these X.
I do not have your data, so I can not say more precisely. The Threshold 1D Array function may be suitable.
(4,090 Views)
Note that you could use the Swap Values function instead of the case structure,
(4,079 Views)
Okay, I have this much. Now how am I supposed to connect to the Array Subset Function. I have attached my VI and data that I'm pulling in case it can help in you assisting. The general idea for this VI is that I am supposed to graph all these points, and have these cursors for when the user wants to save the data in between the cursors, he will be able to by hitting the save button.
(4,064 Views)
It seems that you are not trying to do something
(4,049 Views)
