Extra Character and Line in String Spreadsheet read
Hi All
I've tried to look, but no clue yet. I am using labview 7.1 and trying to read a spreadsheet string file into a string array, but i got extra character in the beginning of the file and extra line in each of the line. I Have tried to put a value in the pos offset, can solve the extra character problem, but it didn't feel right.Text file, source code and result attached. Can Anybody explain about this?
Thanks A lot.
-Just a student-
(3,865 Views)
Hi Nandha,
can you upload your files? Try also the "Read From Spreadsheet File" function.
Mike
(3,854 Views)
These are my files.
The "Read from spreadsheet" function is only applicable for reading numbers, not string.
That is why first i tried to read the file as string, and then split it using "spreadsheet string to array".
My goal is to make an array of strings.
-Just a student-
(3,845 Views)
Accepted by topic author Nandha
Hi Nandha,
your file contains this additional characters (i think it's a unicode file), but the normal editor don't show them. You can see them if you open your file with Word.
Mike
(3,841 Views)
OMG, i didn't realize that
Thanks a lot, Tried to open it from word as plain text, and it did contain the extra character and extra line. Actually i made the text using excel and save it as semicolon delimited, And that is the result.
Once again thanks a lot. Kudos for you.
-Just a student-
(3,837 Views)
