Shared variables problem
I am using LabVIEW 8.5.I am using around 80 shared variables in my project also using Datasocket to read/write them across the network
wanted to know whether I will face any problem while making EXE? Do I have to follow any particular procedure to build exe ?
please help..
Thank you
GAK
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(3,302 Views)
Just follow this KB. For the most part this will ensure you don't run into any problems.
(3,278 Views)
Accepted by topic author Gak
hi,
Thank you for help.will definately work on that.
GAK
Gaurav k
CLD Certified !!!!!
(3,269 Views)
