03-09-2010 12:25 PM
I am using a 3rd party databasing system to store data recorded by a cRIO setup. To do this, I have compiled the necessary library for VxWorks and have instaleld it. Everything was working great with LV 8.6 / RIO 3.0.1, however recently I upgraded to LV2009SP1 and RIO 3.4 to solve other issues I was having. Now my external code does not complete in time when I build an application, however when I deploy the vi using the run button in LV, then everything works great. For example, I timed one piece of code:
Application 107 ms avg
Deployed VI 10 ms avg
My question is, what is the difference between calling the code in an application versus in a deployed vi? I would think that they would behave the same as the library they are both calling does not change. Any thoughts?
Jon
03-10-2010 04:54 PM
Hi Jon,
How have you tested the timing of the external code? One thing to try, if you haven't done this already, is to create as simple a VI as possible that uses this external code. Ideally, this would be one call to the DLL and timing code around this call.
03-12-2010 08:54 AM
Jared,
My code runs in time under LVRT 8.6 /RIO 3.0.1 and also when deploying it under LVRT 2009SP1 / RIO 3.4 . I have created a workaround for this problem by just dumping all of my raw data as a 2D array to the server and having a local program there sort out the diferent channels, the execution time is still higher than I expect, but is more than suitable for my task.
Jon
