Excel Data to LabView Data
I have a file attached below of my code which works perfectly fine (its an extensive project), however, right now when reading data it sends it to an excel spreadsheet and then plots it on a graph in excel as well. What I would like to do is simply do the same except into a LabView spreadsheet and LabView graph; that way I'm not having to use excel. Would like data on graph to look like picture attached.
Any help is greatly appreciated. Thank you in advance!
(2,764 Views)
Accepted by topic author matsuajavier
Hi Matt,
I don't see any "Excel"-related stuff in your VI. Maybe because all of the subVIs are missing!?
Ok, now I found them! That VI is too big, and needs a good cleanup!
You already use several Read/WriteSpreadsheetFile functions: just use one more of them to save your spreadsheet data!
(2,755 Views)
Apologies. I uploaded a new part of my code.
(2,749 Views)
Good day,
Below I have a VI attached which is built to test a flap transmitter (big VI); it works perfectly fine, however, when I run it, it's transmits all the data to Excel spreadsheet and Excel graph. What I would like to do is do the same except to LabView Spreadsheet and LabView graph. Does anyone have any recommendations on how I may go about doing so? I also attached what the VI is currently producing.
An example would be useful. Any help is appreciated, thank you!
(2,728 Views)
Hi Matt,
please don't create double posts on the same topic. Stick with your own thread! (Even when you create a new account…)
Did you try to replace the RGT functions by a simple WriteSpreadsheetFile function?
(2,689 Views)
