Exaprom authorization
Hello JM,
in attchment in LV 2009 form.
Thanks for your help
Message 11 of 17
(1,868 Views)
I will try to give you a feedback Friday.  I have to remove my actual version "Exaprom PDF 2.0" and install "Exaprom PDF 1.0".
From the error message, it looks like the password is not transferred to the PDF Reader.
The PDF document is produce in several steps:
1) Creation of the PDF document and default values including the password (New PDF.vi);
2) Adding contents (text, image, table, etc.):
3) Closing the original PDF document (Close PDF.vi).
Close PDF.vi does a lot of things.
4) Close the original PDF.  At this step the document has no Header, Footer or Watermark (they are store in the XControl);
5) Open a PDF Reader of the previous document.
6) Create a PDF Stamper (who generate a PDF file with a temporary name) linked to the the PDF Reader (step 5);
7) Copy, page by page, the PDF Reader in the temporary PDF file and add Header, Footer and Watermark at each page;
😎 Close the PDF Reader and the PDF Stamper;
9) Delete the original document with no Header, Footer and Watermark (step 4);
10) Rename the PDF File (temporary name) with the name used with New PDF.vi.
It looks like the password is not correctly transferred in the XControl and it is not possible to open a PDF Reader (step 5). In this case, the document produce by the PDF Stamper is empty and iTextSharp is not suppose to allow this.
JM
Message 12 of 17
(1,859 Views)
It is an error in the Exaprom PDF 1.0 palette.
In this version, the password is not use for opening the PDF Reader.
I didn't remember exactly when I made the initial  modification (to fix the problem).
Unfortunatly, the version 2.0 is not compatible with the version 1.0. Sorry...
Message 13 of 17
(1,847 Views)
Hello JM,
I have modify the palette like this
But in the end the pdf lose permissions.
There is an change in an another Vi ?
I don't have the version 2.0.
Where is it ?
Message 14 of 17
(1,837 Views)
1) We open the previous PDF file with the password and permissions (you have already done that).
2) We create a PDF File with a temporary name.
3)  We set the permissions for this file.
Message 15 of 17
(1,831 Views)
Accepted by Jacouille
Many thanks for your help
It's exactly what i ma looking for
Message 16 of 17
(1,811 Views)
Hello Jacouille,
Can you mark J-M's answer as the solution of the issue?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 17 of 17
(1,794 Views)
