Examples using NI-9775 with cDAQ chassis
Where I can find some examples on how to use NI-9775 with a cDAQ chassis (not cRIO).
I can't find them in Example Finder; it can be that I must search them using a different key..
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
Message 1 of 11
(6,192 Views)
Looks like this module is only for c RIO.
The NI 9775, a 4-channel digitizer, can measure transient phenomenon like faults in electricaltransmission lines from lightning strikes or structural failure events at 20 MS/s/ch. Themodule's store and forward architecture allows up to 128 Mbits of measurement data to be sentback to the controller and analyzed. The module has a built-in analog reference trigger, or youcan use CompactRIO and LabVIEW FPGA to develop an advanced trigger based on low-speed streaming data for added flexibility.
Tim
GHSP
Message 2 of 11
(6,173 Views)
I'm not sure about it, for a couple of reasons:
Where did you find that info?
Vix
Using LV from 7
Message 3 of 11
(6,163 Views)
Did you ever get an answer to either of your questions (either the original or the follow-up)? We are looking to use the NI-9775 to repeatedly capture high speed data and save that data to a file for post-processing. I'm hoping there is an example of someone doing this out there. Did you ever get your project started?
Message 4 of 11
(5,348 Views)
Hi @EricWilliamsEPT,
I've never received any answer
Vix
Using LV from 7
Message 5 of 11
(5,327 Views)
There are examples installed with the CompactRIO and drivers.  Does not install in the 64-bit version of LabVIEW.  But if you open the 32-bit version and look for 9775 you should find:
 The path is Toolkits and Modules->FPGA->CompactRio->Analog Input.
Just registered that you have a cDAQ chassis.  Let me check if I can find anything.
Message 6 of 11
(4,873 Views)
Same idea as the cRIO, but in the DAQmx section of the help:  Browse Task.
Hardware Input and output -> DAQmx -> Analog Input....
Analog Input - Filtering.vi calls out NI 9775 support.
I did not have a module but created a simulated cDAQ-9185 added the NI 9775 and ran it in continuous.  Seems to match the documentation on streaming 4MS/s max rate in continuous mode.
 In finite mode all channels can be captured at 20MS/s/ch but the buffer is shared so you are limited to a total of 8.38861MS/s for 1 ch and 8.38861 / 4 MS/s .
Attached my modifications to the standard example.
Message 7 of 11
(4,841 Views)
I am planning to purchase NI-9775 with cDAQ 9171, and I want to use only one channel for continuous data acquisition mode. Will I get the 20 MS/s rate for single channel? If yes what are the other limitations of NI-9775 with cDAQ 9171.
Message 8 of 11
(1,528 Views)
Hi engraqeel,
  • The cDAQ9171 is offered with a USB2 interface, this means the communication is limited to 480Mbit/s (raw!). This typically results in up to 40MB/s transfer speeds (due to data encoding and transfer protocols)…
  • You want to read 20MS/s: with 16bit data this will need 40MB/s, with 32bit data you request for 80MB/s.
For me this reads like a typical conflict between requirements and hardware capabilities…
Generic suggestion:
When you want to handle high-speed data acquisitions you should use suitable hardware!
Asking for (old) USB2 devices is asking for trouble: look for other better options…
Message 9 of 11
(1,518 Views)
If you look at the previous message and the documentation, you will see that 4MSa/s for 1 Channel is possible in Continuous Acquisition mode. The higher sample rate is only available for finite acquisitions of a single channel.
Message 10 of 11
(1,459 Views)
