Example VI for reading Touchstone data files
Can someone please suggest an example VI for reading a touchstone data file (A__S_params.s2p) for me as a starting point. I want to get the magnitude and phase data of S21 to design a filter. I have tried to use Touchstone Data Plugin with the (DataPlugins - ATML) project from the LabVIEW example finder to first convert Touchstone file to TDMS format but have not been successful. Thanks.
Message 1 of 15
(8,909 Views)
Sorry I forgot to attach the data file last time. Here it is.
Message 2 of 15
(8,902 Views)
Still no data file.  Seems to be a lot of that recently.  Anybody at NI monitoring?
Message 3 of 15
(8,889 Views)
Accepted by kathar
Hi Kathar,
The links below might be helpful for you:
http://www.ni.com/example/28433/en/
https://www.ni.com/en/support/downloads/dataplugins/download.touchstone-dataplugin.html
AGJ
Message 4 of 15
(8,853 Views)
A touchstone file is really just a tab delimited text file with some header info.
Bill
CLD
(Mid-Level minion.)
Message 5 of 15
(8,840 Views)
Actually I've seen different flavors depending on the originator of the file. The Touchstone File Specification data line formatting rule just says that individual entries are separated by whitespace. HP-ADS separates the values with multiple space characters, the N5230A and C uses a single space character, the E5071C uses a single tab character. I usually replace multiple spaces or tabs with a single tab before processing the data.
Ben64
Message 6 of 15
(8,834 Views)
Ben64
That's the truth.  I don't know why I said "tab" because I've seen different formats, too.  The point I wanted to make was that ultimeately it's just a parsable text file.  🙂
Bill
CLD
(Mid-Level minion.)
Message 7 of 15
(8,816 Views)
I am grateful to all of you who have responded. I have downloaded the Touchstone Toolkit v1.00. Here are the instructions for installing the toolkit:
Installation Instructions
1. Place the Touchstone Toolkit v1.00 and the errors folders in the C:\Program Files\National
   Instruments\LabVIEW 6.1\user.lib directory.
2. Restart LabVIEW to refresh palettes
3. Two new palettes will be added
 Controls Palette- User Defined Controls sub palette : Touchstone Toolkit Palette
 Functions Palette -User library sub palette: Touchstone Toolkit Palette
I have two questions:
1. Is there a more recent version of Touchstone toolkit? If so where can I find it from?
2. I am using LabVIEW 2013. In which folder I should place the above two folders so that two new palettes are added.
Thanks.
PS: I am having difficulty adding screenshots and files to these messages.
Message 8 of 15
(8,805 Views)
Accepted by kathar
Put it in your corresponding user.lib folder.  That's really neat that you dound a toolkit!  It will probably work just fine.  🙂
Bill
CLD
(Mid-Level minion.)
Message 9 of 15
(8,796 Views)
I have just placed both the folders in the user.lib folder and have restarted LabVIEW.  I can see both the palettes now with all the functions and controls. That should help solve my problem. Thanks to all of you.
Regards and best wishes,
Kathar
Message 10 of 15
(8,784 Views)
