取消
显示结果
搜索替代
您的意思是:
Event case controlled by DAQ
Hello everyone,
I would like to control an event case with a digital input from the DAQ, so that when the input is at 1 the event case is carried out.
Can anyone help me?
Niccolò
0 项奖励
1 条消息(共 9 条)
2,303 次查看
Try using User Events to trigger an event whenever you receive the DAQ Input as 1.
0 项奖励
2 条消息(共 9 条)
2,297 次查看
thanks for the reply, hob just tried but it still doesn't work
0 项奖励
3 条消息(共 9 条)
2,291 次查看
Please do share the one which you tried, so that we can suggest you to get your problems resoved
0 项奖励
4 条消息(共 9 条)
2,282 次查看
What DAQ are you using and what is your goal?
Santhosh
Soliton Technologies
0 项奖励
5 条消息(共 9 条)
2,241 次查看
If you have a board that supports it, then you can use the Change Detection Event.
The Example finder has "Voltage (with Events) - Continuous Input.vi" for voltage input. For digital events, the structure is similar. Something like below to start
then wire the dynamic event registration into the Event Terminal, then make the corresponding event case
6 条消息(共 9 条)
2,232 次查看
I tried to create a User Event and use it to activate the Event Case.
I'm at the beginning of Labview I don't know if it's right. 
0 项奖励
7 条消息(共 9 条)
2,192 次查看
I'm Using the DAQ NI 9375 and I would like to use my input as an event case activation
0 项奖励
8 条消息(共 9 条)
2,191 次查看
Hi nick,
You did it wrong…
I recommend to learn from the example VIs coming with LabVIEW, found in the example finder!
You need to enable user events in your event structure and you need to register the user event for that event structure!
(Why do you need an event to put some data into a queue? Why not do this in your DAQ loop?)
0 项奖励
9 条消息(共 9 条)
2,180 次查看
