Event Structure for inactive window
Hello, I am wondering if there is an easy way make the user events more consistent when the front panel of a VI is not the active window (in Windows). I notice that when a front panel is running but not the active widow I still get button animations and mouse enter and exist events but I don't get button press or mouse down events unless I first click on the window to make it active. I would really like to get the button press and mouse down events even if the window is inactive. If that is not possible, I would like to disable the animations if the window is inactive. I have provided a VI that demonstrates this behavior.
Thanks for looking
______________________________________________________________
Have a pleasant day and be sure to learn Python for success and prosperity.
Message 1 of 27
(1,402 Views)
When an app that is not the active window receives mouse click events, that is called 'click-through'. I believe that it is an OS setting/characteristic.
Message 2 of 27
(1,387 Views)
Yes, this is expected - and desired - behavior.
Bill
CLD
(Mid-Level minion.)
Message 3 of 27
(1,361 Views)
Which do you mean?
  • It's desired that it be an OS setting
  • It's desired that there should be click-through
  • It's desired that there should not be click-through
Message 4 of 27
(1,352 Views)
Which do you mean?
As an end user of an application, I think the expected behavior is that if I'm hovering over a button and the button is animating, I expect that clicking the button would do the thing linked to the button ... I don't care if the window is active or not.
Message 5 of 27
(1,331 Views)
Inactive window does not get mouse click message is the Windows default behavior.
LabVIEW buttons are not Windows objects.
Why animation works?  An NI mistake.  Should not overwrite Windows default behavior.
George Zou
Message 6 of 27
(1,323 Views)
I think this works
I don't know why the Event Structure is blank, should be Pane:MouseEnter
Message 7 of 27
(1,302 Views)
Which do you mean?
It's desired because if a pop-up shows up in front of the app that has focus, the first click on a button on the pop-up will set the focus, not click the button.
Bill
CLD
(Mid-Level minion.)
Message 8 of 27
(1,283 Views)
Which do you mean?
Beyond that, I want the following OS setting:
DontMoveStuffAroundUnderTheMousePointer = TRUE.
Message 9 of 27
(1,279 Views)
Snippets do not maintain static links (UI events, locals, static refs, linked properties, linked methods) to front panel elements that cannot be included in the snippet itself, such as panes and splitters.
Message 10 of 27
(1,256 Views)
