Event Structure for inactive window
@billko wrote:
It's desired because if a pop-up shows up in front of the app that has focus, the first click on a button on the pop-up will set the focus, not click the button.
Do you mean a popup from the app that is the original active window or a popup from some other app?
______________________________________________________________
Have a pleasant day and be sure to learn Python for success and prosperity.
Message 11 of 27
(565 Views)
@zou wrote:
Inactive window does not get mouse click message is the Windows default behavior.
LabVIEW buttons are not Windows objects.
Why animation works?  An NI mistake.  Should not overwrite Windows default behavior.
I have been clicking around on apps all day today to see what they do in this case. I have found that *most apps* will act on a button click even though the window is not the active window. I agree with *most apps* that an app should honor a button click no matter the window state, especially if the button is animated.
Message 12 of 27
(547 Views)
According to this old discussion , there was once an ini setting (dropThroughClicks=True) to control that. Not sure if it still exists.
Message 13 of 27
(537 Views)
That is exactly what I am looking for but I do not see the option in LV2021.
Message 14 of 27
(500 Views)
The ini modification would be best, but the low level window command did work in Win11, 2024Q3
Message 15 of 27
(494 Views)
Do you know if there is a similar .net call?
Message 16 of 27
(480 Views)
I'm sure there is, but good luck finding it. According to AI
  using System.Runtime.InteropServices;
    public static class WindowHelper
        [DllImport("user32.dll")]
        [return: MarshalAs(UnmanagedType.Bool)]
        private static extern bool SetForegroundWindow(IntPtr hWnd);
        // ... other methods
Is that the mscorlib?
Message 17 of 27
(469 Views)
There are lot of conditions needs to be met to get this running and related to the thread...
Use SetWindowPos instead https://learn.microsoft.com/en-us/windows/win32/api/winuser/nf-winuser-setwindowpos
Message 18 of 27
(454 Views)
Moving the window to the foremost would set its position on top in Z order. What other conditions, considerations are needed? A quick test showed that the call to the DLL worked. Am I corrupting the memory?
Message 19 of 27
(446 Views)
I mean these:
The system restricts which processes can set the foreground window. A process can set the foreground window by calling SetForegroundWindow only if:
  • All of the following conditions are true:
  • Additionally, at least one of the following conditions is true:
    • The calling process is the foreground process.
    • The calling process was started by the foreground process.
    • There is currently no foreground window, and thus no foreground process.
    • The calling process received the last input event.
    • Either the foreground process or the calling process is being debugged.
For me (LV2025 Q3 x64 v.25.3.2f2 on Win11 LTSC 24H2 v.26100.4946) SetForegroundWindow doesn't work, the FP window was not brought to the foreground, and the return value is zero (and yesterday evening I was too lazy to check it why exactly).
Message 20 of 27
(421 Views)
