Event Structure & Add Stop priority during a process
Hi all,
In my program, I use an event structure and during a process, I want to add Stop Emergency button.
How can I do ?
(4,595 Views)
What exactly should this emergency stop button do that isn't already being done by the stop button you have in there now?
(4,590 Views)
For example, if the process has 10 step, Emergency button can stop at least between 2 step
(4,549 Views)
Use a state machine and don't congest event cases. They should always completed immediately.
What happens in the various "steps". Just a waits or something that takes a while and cannot be interrupted?
(4,543 Views)
something that takes a while and cannot be interrupted, so wait the end of 1 step before interrupt
(4,536 Views)
Again, don't use a sequence. Use a state machine and check termination after each state.
(4,529 Views)
ok, I never use State Machine, I will look for an example
(4,527 Views)
