EtherNet/ IP basics
I'm looking for some basic info on using EtherNet IP conmms with LabView. In the past I've using RS-Linx and LabView datasocket to communicate with a PLC. Can I use a similar approach with EtherNet IP? Do I need the LabVIEW Driver for EtherNet/IP, Driver for EtherNet/IP and RS Linx or just RS Linx?
Simon
(5,418 Views)
You just need the LabVIEW Ethernet/IP driver.  And there are some decent examples if you look for them (Help->Find Examples).
(5,388 Views)
OK thanks. That's what I needed to know.
(5,371 Views)
