Quadratic Formula question.
If I was using the quadratic formula in Labview (-b±√b²-4ac/2a,) how would I represent the ± using the Mathmatics functions?
Message 1 of 10
(10,289 Views)
Do you understand what the Quadratic Formula means?  [I was just talking to a high school sophomore about this -- she didn't get it, either].
All quadratic equations have two (2) answers.  A mathematical short-hand to write both of the answers with fewer pen strokes is to use the symbol ± to mean "One answer uses + and the other answer uses -".  How would you take three numbers (the coefficients of the second degree polynomial) and produce a two-part answer (in LabVIEW)?  How would you represent that two-part answer?
Message 2 of 10
(10,273 Views)
Out of interest, how do you get LabView to generate a complex result when the parameters demand it?
Message 3 of 10
(10,242 Views)
I still cant figure it out. Here is a screenshot of both my Block Diagram and GUI.
Message 4 of 10
(10,228 Views)
Simple -- feed the real and imaginary parts into the Re/Im to Complex function and out pops a Complex number.  Look on the Numeric palette.  [If you don't see it, your version of LabVIEW is "too old"].
Message 5 of 10
(10,223 Views)
Don't attach a picture -- attach the VI itself.  This lets us "play with it" (and run it to see what it does).  It's not that we're too lazy to squint at a tiny image and try to painstakingly reproduce your code, but then you'd have to triple what you are paying to use the Forum ...
Message 6 of 10
(10,219 Views)
You can literally google image search "quadratic equation labview" and find how someone else has already solved this in LabVIEW.
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
Message 7 of 10
(10,184 Views)
Bob Thats not the question I was asking: If I wire a complex type out of the square root function, will it automatically generate a complex result when the input to the square root function is negative? Or, more generally, will all Labview arithmetic functions work correctly if wired with `complex` wires?
Message 8 of 10
(10,152 Views)
I would imagine all the basic math primitives will work with complex - enough to solve your quadratic.. but a lot of stuff won't. It would only take you a minute to try it.
Message 9 of 10
(10,137 Views)
That's a good question -- I do not know the answer, but I can (and did) find out in less than a minute.  I opened a new VI, created a Dbl constant (4), wired it to a Sqrt function, and wired a Dbl and a Complex indicator to the outpu.  I ran it, it returned 2 (dbl) and 2+0i (complex).  I then changed the input to -4 and tried again.  I got NaN and NaN+0i.  Finally, I changed the input representation to Complex (so it read -4+0i).  When you take the minute to do this yourself (which you should have done, rather than ask us to just give you all the answers), you'll learn how LabVIEW handles Complex quantities.
Message 10 of 10
(10,107 Views)
