If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
03-29-2018 08:41 AM
Hello All,
I have a software that written by a supplier and there were some issues with the global destination path for one of the cards. I have the full project so I did fix the problem and I saved all. After built a new installer and application and everything goes good to complete the built. I installed the new installer and an error 7 message popped up. In the attachment you will find a snap of the error message that I am getting. Can any one help me please with this? Thank you all for your time.
03-29-2018 09:06 AM
Hi Ziad,
Can you provide us with the part of the VI where you build the file path ?
My guess is that you use the "Current VI's Path" VI without removing the VI name before building the rest of the path. At least that's what I understand from the error I see.
Thanks.
03-29-2018 10:19 AM
Do you mean a snap for the project building specifications? , Sorry I am new and self learning LabVIEW and this is a huge software with more than 100 VI's
03-29-2018 10:36 AM
I'd attach Main.vi and CRCCOL Shunt Calibration Global.vi, the VIs that were running when the Error occurred. Be sure to attach VIs, not pictures -- we need to "see it all".
03-29-2018 11:56 AM
here are they
03-29-2018 12:13 PM - edited 03-29-2018 12:15 PM
In CRCCOL Shunt Calibration Global.vi, what's the output (value) of this subVI ?
03-29-2018 12:22 PM
I almost hate to say it but.......
CCCROL and CRCCOL makes me think there is a typographical error.
03-29-2018 12:36 PM
Ooooooh, sneaky one...
03-29-2018 01:52 PM
So what should I change ? Where did you find the typographical error? I know everything is saying CCCROL but the call of this file is written CRCCOL. Please check the attachment snap.
03-29-2018 02:03 PM - edited 03-29-2018 02:04 PM
I think it is just a guess from Jeff. We looked at the path given on your error screenshot where you can find both CCCROL and CRCCOL. So either there is a mistyping of something, either you build the wrong path. In any case, LabVIEW cannot locate the file...
To find out the source of that error, can you please send us the Paths.vi or at least tell us what is the path it outputs when Configuration Path is selected ?
