Error while reading TXT file
I manually update data from .xlsx to .txt
I use labview to list and select items from srcolldown menu.
I attached my VI.
If run my VI at very first startup 'na' is selected by default from list. Meanwhile I get error codes such as 'creating .csv file' and 'writing data to .mdb file' until i select another item in listbox, e.g.: 'First line'. After then If i select any other items from list error codes disappear. I then can choose 'na' again and it will work.
Scroll down menu content:
na
First line
Second Line
Third line
etc
Why 'na' is not accepted at first startup?
Kind regards,
Balázs
(1,244 Views)
Accepted by LTBALAZS
Hi LT,
na
First line
Second Line
Third line
etc
At first startup the ring is empty, but yet you write the string into the listbox value property. As the ring doesn't know that value it cannot select/accept it as valid value. Then you parse the string into its lines and set  the ring item strings. Now the ring knows it's list of valid values and can accept the "na" on the second try…
Another problem is: you write the whole text file content into the value property: what should the ring do with this full length string?
Btw. don't talk about "list" and "listbox" when you are using a ring control…
(1,217 Views)
Thanks!
(1,136 Views)
