Error message "VI is not executable"! Need help with Application Builder
Thank you all for your answers! I spoke with the supervisors from school and it's okay if it is not an really executable... So, I don't need to spend more time in this part of the project!
However, I will connect the error nodes and place an indicator on the front panel. The state machine cannot be opened because I've 8.5 and not 8.6, but I saved the file and I will try to take a look if I have more time and a machine with 8.6!
Thank you for your answers, especially LabBEAN!
Kind regards,
Sebastian
Message 11 of 13
(681 Views)
That makes since too...  The machine that you need to use has labview already installed on it anyways.  You will like not having it as an executable too.  Its nice because you can make programming changes on the
Something you might want to do since you are using 8.6: You can actually use the app controls to turn off the capablities of modifying the front panel.  It nice since you can make accidental moves.
Message 12 of 13
(674 Views)
You're welcome Sebastian.  See attached for 8.5 version.  There is much to be said about architecture on these forums.  (Another disclaimer [before others hammer me about using a string queue instead of enum bundled with variant]:  This one is very basic.)  Have fun!
Certified LabVIEW Architect
TestScript: Free Python/LabVIEW Connector
One global to rule them all,
One double-click to find them,
One interface to bring them all
and in the panel bind them.
Message 13 of 13
(657 Views)
