Error code list for LV ?
What are possible code error for the Copy VI ? I need to know if the file in destination already exist to ask if the user overwrite it or change name. What's the method. Thanks.
In most general, is there a global list code error reserved for LV ? Thanks.
(3,611 Views)
There's a vi called general error handler which contains all errors reserved for LabVIEW and descriptions of them. You also can add your own error codes.
Hope this helps
(3,611 Views)
You also have the error codes in the online help, listed by different types.
Good luck
(3,611 Views)
Hi GAP,
find attached a small part of typical save-procedure after measurements. I have cut back everything not needed for you. I test in that way, if a file is present; append results or throw away the old file,if "single" is selected. Herewith I also know - do I have to add e.g. a header?
Regards
wha
(3,611 Views)
