Error code database is password protective without putting a password!!!
I am using LabVIEW 8.6.1. Everyitme I use the "find and replace" option selected from the edit menu I get the notification "error Code database. vi is password protected...", please see the full message on the attached screen capture. I have never put a password. Can somebody suggest why this is happening and advise how to stop it. The skip option works however I don't want this inconvenience.
Thank you in advace
Message 1 of 11
(5,862 Views)
Hi thorfano,
is this  subvi from you? Maybe it's from NI and they use sometimes a password.
Mike
Message 2 of 11
(5,858 Views)
Hello Mike. Thank's for your response. I am not sure if I gave you understand what I am doing. In a vi that I did by myself I select "find and replace"choice (from the "edit"of labVIEW menu) and looking for a text that exists in my vi. e.g SP O2%. Then the message sent before appears. What I am doing has nothing to do with the "error code database vi" at least I can't see the correlation.
Thank you
Message 3 of 11
(5,851 Views)
Hi thorfano,
it's definetely a vi from NI. It's the database for all those error messages and hidden somewhere in the "general error handler" vi.
You probably used this (or any other related function) in your vi hierarchy and so the search also tries to access this function when searching for text...
Message 4 of 11
(5,847 Views)
Thanks Gerdw for your reply. Thus, you say its normal to get this message and I can't do nothing (rather than select "skip") to prevent message apperance. Am I right?
Thanks in advance
Message 5 of 11
(5,838 Views)
Accepted by LW42
If you only want to search in your current VI then select that as scope. If you want to search in all VIs loaded into a particular instance I do not think you can avoid that stupid dialog currently.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
Message 6 of 11
(5,821 Views)
Rolf Kalbermatter
Isn't there a 'Ignore VI.lib' Setting for that dialog as well?
That should help.
Ton
My LabVIEW Ideas
Message 7 of 11
(5,798 Views)
Ahhh yes, that seems to be a feature since LabVIEW 8.0.
Rolf Kalbermatter
Message 8 of 11
(5,790 Views)
Good morning,
Thank you all for the help, the choice "ignore vis in vi.lib" is ticked (selected) and I wonder why it doesn't work. I checked and found that the "error code database vi"is inside the vi lib as expected. I also checked if somehow the "error code database vi" is present in another location in my computer, nothing found.
Best regards
Message 9 of 11
(5,766 Views)
thorfano,
add a Kudos and perhaps a comment to this LabVIEW Idea.
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
Message 10 of 11
(5,746 Views)
