Error code 45
I am trying to load a vi that was written in version 8.6 with version 9.0. I received the following error message "Labview error code 45: An error happened while updating the VI's fonts" and the loading terminate.Please advice.Regards
(4,987 Views)
Hi gabi,
attach the vi, maybe someone else may be able to load/convert it... Otherwise NI R&D still has a good example to look at for bug hunting Smiley Wink
(4,980 Views)
Are you still able to open the VI in 8.6.x?
Are you able to open other 8.6.x VIs with LV9.0?
Can you post the VI?
Christian
(4,979 Views)
Accepted by topic author gabi_hor
Hi
Thank you all for your replay.
Its working, I play around, I am not sure what I have done, but its working.
(4,976 Views)
Could it be that you're missing some font?
Qestit Systems
Certified-LabVIEW-Developer
(4,975 Views)
