Analog edge trigger
I wonder if my USB 5133 can be triggerred, when input is a DC higher than the threshold of analog edge trigger in the setting.
Any suggestion, thanks.
(3,026 Views)
First of all you should better post such questions in the hardware forums than here.
That beeing said, the manual of the USB-513x says:
Triggering and Clocking
• Edge, window, hysteresis, and digital triggering
• Ability to capture pretrigger and posttrigger acquisition data
• Internal 100/50 MHz clock or external clock from 1 MHz to maximum
  sample rate
Christian
(2,989 Views)
