Error code 45
I am trying to load a vi that was written in version 8.6 with version 9.0. I received the following error message "Labview error code 45: An error happened while updating the VI's fonts" and the loading terminate.Please advice.Regards
(4,787 Views)
Hi gabi,
attach the vi, maybe someone else may be able to load/convert it... Otherwise NI R&D still has a good example to look at for bug hunting Smiley Wink
(4,780 Views)
Are you still able to open the VI in 8.6.x?
Are you able to open other 8.6.x VIs with LV9.0?
Can you post the VI?
Christian
(4,779 Views)
Accepted by gabi_hor
Hi
Thank you all for your replay.
Its working, I play around, I am not sure what I have done, but its working.
(4,776 Views)
Could it be that you're missing some font?
Qestit Systems
Certified-LabVIEW-Developer
(4,775 Views)
