Error Cluster Bug Report (LV 2011)
As I was trying to comment on an Idea Exchange Thread, I stumbled upon this bug.
Drop the following on a diagram:
Then try to "Create Indicator" from the OR function output:
Then Run the VI (or try to compile it using Ravens Fan's favorite trick of Ctrl-Run Arrow). Here is what I get:
The VI is now broken.
If I delete the indicator, it doesn't fix the problem. If I delete the operator, it does.
Message 1 of 17
(4,714 Views)
I'll confirm it for LV2011.
I don't know what the expected result should be of OR'ing a cluster.  But the error message that pops up is certainly ambiguous and deep from within LabVIEW.
Message 2 of 17
(4,698 Views)
This is indeed something special...
Nice find!
However, I still find an OR operator with one input a bit weird 🙂
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 3 of 17
(4,697 Views)
Using 2 inputs (expanding the compound) you'll only get a boolean out.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 4 of 17
(4,693 Views)
@ThiCop: That's the whole idea of "More Compact Operators"!
@Yamaeda: That was exactly what I was trying to "create": a simple operator that would convert an error cluster into its Boolean component. So I shrunk the operator and to my surprise (but again that may be the "expected" behavior ;-), the output reverted to an error cluster. Then bam!
Message 5 of 17
(4,689 Views)
And then  you didn't use the unbundle by name because it had to be more compact?
Kind Regards,
Message 6 of 17
(4,665 Views)
Except that a single-input OR gate is basically a synonym for a wire.
Mike...
(who thinks trying to assert a copyright on a forum post is really lame -- especially when it doesn't say who is asserting the claim)
Certified LabVIEW Architect
LabVIEW Champion
Message 7 of 17
(4,664 Views)
I did, precisely for this reason.
Message 8 of 17
(4,644 Views)
I couldn't agree more. Moreover I think the whole idea of a signature is annoying. Which is why I turned the option of displaying signatures off. As a matter of fact, even the idea of avatars irritates me. In particular those which try to be original and poke fun at... now I am getting in trouble!
Message 9 of 17
(4,640 Views)
I'm with you on that one! (cough cough hack hack)
I'm better some years than others...
Smiley Wink
back on topic
I agree that no user actions (short of type casting) should crash LV.
Ben
Message 10 of 17
(4,632 Views)
