Error 85 occured at Scan from String (arg 1)
Running into an issue I haven't been able to solve yet. Trying to communicate with a Sierra Instruments flowmeter. The flow meter has no issue communicating with its intended software, so I know it is not a driver or cable issue. I have attached a reference on the command overview. Also attached is my VI and screenshots. My comm settings are correct.
Message 1 of 14
(2,637 Views)
Hi Parker,
We don't have your instrument, so for us to help you, you need to tell us what are the bytes expected in return of your command, or at least attach the datasheet.
Raphaël.
Message 2 of 14
(2,626 Views)
Hi Rapheal,
According to the datasheet, each command has a length of 2 bytes. The response to the command is also 2
bytes. The low byte is always transmitted/received first followed by the high byte.
Thanks!
Message 3 of 14
(2,622 Views)
Hi derek,
why do you think you could use ScanFromString here?
Use StringToU8Array, index the bytes as needed and do whatever you want to do with them…
Message 4 of 14
(2,592 Views)
Accepted by parker300
This device is using hex/binary/raw data formats.  So...
1. You need to turn the Termination Character OFF
2. The Scan From String will not work.  Use Unflatten From String instead.
The Scan From String is expecting ASCII text.  But your device is sending the data in its raw format.
Message 5 of 14
(2,588 Views)
For future readers, here is the part of the datasheet that describes the command and answer:
 's solution implements that perfectly.
Message 6 of 14
(2,579 Views)
Crossrulz,
Thanks for the help. When I copy your code, I get this error 74 message, saying my data is corrupted. Do you know the root of this?
Message 7 of 14
(2,549 Views)
Regardless, setting a default data to littoral "%x", leaving the format specifier blank, (default specifier %f) then, passing in an hex codes string is just as wrong as you can be!
 You could use Scan from String with a %x format specifier and a default value of 0 AS U16 or I16 then use swap bytes.  However,  the Unflatten From String is more scaleable.
"Should be" isn't "Is" -Jay
Message 8 of 14
(2,546 Views)
@parker300 wrote:
Crossrulz,
Thanks for the help. When I copy your code, I get this error. Do you know the root of this?
You tried to unflatten to an array of integers rather than a scalar integer. Worse, you are only getting two character on your read String and you might need to read 4 e.g "6209" equals 0d 2402
 Probe the read string! Is it "6209" or "c\t" ,lowercase c horizontal tab,
Tim must be decaffeinated today.
Message 9 of 14
(2,511 Views)
@JÞB wrote:
@parker300 wrote:
Crossrulz,
1. I don't drink coffee, so I'm always decaffeinated.
2. Look at the data sheet.  It clearly states the response is 2 bytes.  The example is showing the two bytes in hexadecimal, showing the combination, and what the decimal equivalent would be to make it more human readable.  Further, in \ Codes it should show "b\t", a lower case b and a tab.
3. Looks like Jay is the one who needs coffee.
Message 10 of 14
(2,484 Views)
