DAQ not seen in LV but working with MAX
Hi
As stated in the subject, I have an LV 2020 Pro on a Win 10 PC, with a DAQmx device for reading temperatures.
On the same PC I used to have a LV 2022 which worked fine. Disregarding the "if ain't broken don't fix it" I removed the 2022 and installed the 2020 Pro licence (I have a dozen PC with LV, and around 8 to 10 LV licences, I wanted to re-organize all these since NI changed, unfortunately, their pricing policy).
After installing the LV2020, the DAQmw is not seen by LV, except if I use the "express" thingy which I don't like. I can read and control the Daqmx device in Max, but the tasks are not seen in LV.
What is the problem ?
(I have updated LV to 2020 f2, "repaired" DAQmx... nothing changes.
Thanks for help
(911 Views)
Only tasks are not seen? What about the physical channels?
Right-click on the control and select I/O Name Filtering. What is the current setting?
https://tmesystems.net/
(894 Views)
good question.
Not only ttask, nothing is there. I've seen this suggestion in NI Help but when I right click on the control I don't get this I/O Name Filtering
(890 Views)
