Error 20017 with CompactDaq and Labview
Hi everyone,
I created a pretty simple VI for monitor and control of some pneumatics with  NI 9205, 9213, and 9264 modules in a cDaq 9178.  The chassis was used for a different VI with differnet modules in various slots.  Upon returning to this original VI and application, each DAQ Assistant is sending error 200170 when we hit run.  The error message and VI are attached.  We have verified that each channel is properly assigned and have tried deleting each module from NI MAX under devices and interfaces.  A quick fix here would be hugely appreciated!
Best,
Jack
(1,875 Views)
We are also getting this message when I try and reconfirgure channels!
(1,872 Views)
Hi Jack,
Quick fix: don't use the DAQAssistent, but just plain (and easy) DAQmx functions! Define the DAQmx tasks in your VI…
(1,868 Views)
Accepted by Jack_Oswald
Ha, I'm sorry that we're still using it Gerd.  A new hire is going to build out a more robust system for our CRio.  Also, we found our bug, so I'm closing this thread.
(1,848 Views)
