Equal?
Hi, i have two 1d arrays with 7 elements inputting into a equal? comparison. My question is when the equal compares the two 1d arrays does it compare the entire are array of elements to the other array of elements. Or does compare one element from one array to the other element in that array untill its gone through all the elements.
Stu
(3,873 Views)
Accepted by stu22
During comparison, it will check the corresponding index values only. So a(0) is compared to b(0) and a(1) to b(1). See the attached sample.
Message Edited by Mathan on 03-11-2010 06:21 AM
(3,869 Views)
Please keep in mind that comparing floating point numbers to "equal" is a bad idea. So do not compare to arrays with floating point numbers with the equal function.
Norbert
Norbert
Expert: Geometry
(3,856 Views)
There is more to it than that.
If you right click on the = comparison, there is a a menu choice for Comparison Mode.  By default, it is Compare Elements and will return an array of booleans comparing element to element.
If you choose Compare Aggregates, then you will get a single boolean that is a comparison of the complete array to the other array.
So you can get both choices.  All you have to do is set the comparison mode the way you want.
(3,835 Views)
Dear Stu,
You can better mark Ravens Fan post as solution since it is having very much information than mine.
Mathan
(3,795 Views)
hi,
Not sure if this is worth mentioning... when working with two arrays, the arithmetic takes effects up to the shorter one (in size)...
Correct me if above is not correct. Thanks!
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(3,780 Views)
