Enum/Ring Customization - How to colorize selector?
Dear colleagues, I need you tip or hint, probably I'm looking for too complicated solution in simple situation.
What I need is to customize visual appearance of the controls according GUI spec. I can easily achieve such result:
So far so good, but when user hit the control to choose an item, the appearance is different:
My question — is any trivial way exist to customize selector, which should be a little bit larger, dark as shown on the left side and  with required accent color?
If I have had LabVIEW NXG, then easily can achieve this with WPF Control, but I'm on LabVIEW Classic.
I'm experienced enough to create XControl, where I can do almost everything, but at the same time I'm lazy enough (it is quite amount of work), may be I overseen very simple, but generic solution? Later I will need to localize this to other languages, and there are many such controls (not always two items as shown above, could be also 20, etc).
Any idea?
(1,399 Views)
Accepted by topic author Andrey_Dmitriev
Update: This could be partially achieved by Environment's settings:
Now it looks better, the only blue color a little bit "wrong":
and selection's color can be changed in registry:
Now looks better:
More or less acceptable.
(1,366 Views)
Too bad it wasn't a complete solution.  😞
Bill
CLD
(Mid-Level minion.)
(1,346 Views)
Well, the next trouble in this journey will be the fact, that in LabVIEW you can't align text vertically in the cells, which is required here and some other things...
But impossible is nothing, of course:
Anyway turn this "coffee break" exercise into "generic" solution (with scroll bar for many items, etc) will require huge amount of work.
(1,279 Views)
