Embed Video from Axis IP Camera into VI to be used with LV 8.6 Web Publishing tool
Hello, I really like the Web Publishing tool. I have used it several times. I wanted to add the feature of an embedded live video of an Axis IP camera feed on the front panel. Has this been done before? Can it be done? I have CVI & Vision. I know it can be done with NI's hardware but I would need a NI's card & camera. There is nothing special about the Axis IP camera other than it has good quality.
Roy L. Costa
Email: roycosta@hotmail.com
Catalyst Test Engineer
General Motors Warren Tech Center (R & D)
(4,357 Views)
I've attached an example that shows how to stream an mpeg video, is that what you are looking for?
Jeremy_B
Applications Engineer
(4,297 Views)
Jermey,
I am taking about a live feed coming from a IP camera.  I believe I found an answer.   I found an example on NI's website.  Also, I was lucky becuase Axis camera had ActiveX containers to download.  So far, so good.  Thanks.
Roy L. Costa
(4,291 Views)
Can you share me, what was that example?
Thanks!
Kolos
(3,921 Views)
