Elapsed time
Elapsed timer doesn't start from 0 when transitioning from idle state (start button) to close state after first transition.
Also, when trying to transition between open state and close state it locks up in the close state.
(4,701 Views)
get rid of your while loops.....wire your elapsed timer "reset/time has elapsed" with a bool shift register. once the time has elapsed...transition to your next case using "select"
(4,679 Views)
Sorry but I don't get it.
Shift registers on outer while loop ?
I put the elapsed timer in a while loop because there will be daq in parallel.  Maybe there is a better technique for that.
Do you know why the timer doesnt start at zero after first time through the loop.
(4,669 Views)
Accepted by topic author ggress1
 yes
Maybe there is a better technique for that....yea,just use one main loop for now
(4,654 Views)
I need it to count elapsed time while in the closed state.  This method will only increment elapsed time on transitions between states.
(4,646 Views)
Ok got it....also technique is described below.
http://digital.ni.com/public.nsf/allkb/05A9C3B0A4D5A7638625712B006FB30F
Thanks !!!
(4,636 Views)
