Efficiently saving front panel parameters
Hello.  Just a quick question:  Is there a way to efficiently poll all the parameters set on the front panel and save them to a file to be loaded later?  I know that this is possible by individually making keys for each, but my front panel has a whopping 38 parameters that need to be saved.  Using the methods I've found online and elswhere in this forum, saving a large number of parameters is possible, but would be very, very tedious.  I was just wondering if there was a more efficient way, like a command to poll all controls present and bundle them into an easy to manipulate cluster.
Message 1 of 10
(4,542 Views)
Also, the version I'm using is 2009 SP1, to clarify.
Message 2 of 10
(4,540 Views)
The quickest and dirtiest approach is to use
Operate >>> Data Logging >>> Log
Once written can be retrieved.
Ben
Message 3 of 10
(4,529 Views)
You can use the invoke node of the This VI reference to "Get All" controls/indicators and the "Set" method to set one (see attached snippet). Programmatically editing the data is tedious however as the data is retrieved as variant. The OpenG library has some great VI's for working with variants should you choose to do so.
Charles Chickering
Message 4 of 10
(4,527 Views)
Perhaps these would work.
Message 5 of 10
(4,513 Views)
Accepted by topic author RBeck
LV 9 versions
Message 6 of 10
(4,510 Views)
pcardinale,
Thanks. That was a very useful VI. I was looking for a way to process this data outside of OpenG. (I attempted with OpenG, compiled the application and was immediately hit with trojan virus warnings. I downloaded OpenG's solution just 4 days ago.)
The XML based VI's you present are very clever.
Message 7 of 10
(4,478 Views)
Thank you all.  This is very helpful.
Message 8 of 10
(4,465 Views)
Your programs are great, but could you briefly go into how to use them?  I'm currently using a sequence structure to make my program go Read->Actual Program->Write, but that doesn't seem to do anything.  Also, does this program have support for saving and loading multiple configurations?  Just curious.
Message 9 of 10
(4,447 Views)
