Edit rownames in multicolumn listbox at runtime using keyboard
Is it possible to edit rownames in multicolumn listbox at runtime using keyboard?
Message 1 of 23
(4,813 Views)
Hello Michael.Koppel…,
Of course it's possible but not like in dev mode.
Using user event you can get the keyboard values. Using property node, you can change the row column headers and values.
You got everything you need to know, the only things left is coding Smiley Wink
Good luck.
Sabri JATLAOUI - Certified LabVIEW Architect - Certified LabVIEW Developer
Message 2 of 23
(4,808 Views)
Do I need an popup inputbox  to put in the new value ?
Message 3 of 23
(4,805 Views)
I have done that, or use an input control like a table that the user can type in.
The advantage of the separate pop-up is that you can customize it to do data validation for you and thus prevent the user from entering invalid data.
Mike...
LabVIEW Champion
Message 4 of 23
(4,796 Views)
it's a good idea.
It's depend of what you want to insert in the element.
If you have a defined small number of possible element you can create a contextual menu in your mouse right click. It's the neat solution.
You can use a pop up, shortcut....
Plenty of solutions depending on your requirements..
Message 5 of 23
(4,790 Views)
Hope many people provided different views, i would like to share one kind of view which i handled earlier in one of my project.
Steps to br followed
1.Create a event for the Multicolumn textbox with Mouse down as event trigger.
2.In the event you can select the element Named Coordinates.
3.Use Point to Row cloumn Invoke Node and Provide the co ordinates as input to invoke node.
4.From the output of Point to Row cloumn Invoke Node you will get Cell position.
5.Provide the cell position value as input of multi column textbox edit position.
This works fine for me
Message 6 of 23
(4,770 Views)
Thank you for your input.
I made this example inspired of your reply.
My idea was to move the numeric indicator over the input cell of the MCL and transfer the value to the MCL cell.
The problem is that
1) the indicator position is not exatly over the MCL cell and
2) you have to first put the value in the indicator and after that click a cell in the MFC.
Message 7 of 23
(4,742 Views)
Use the mouse coordinates to determine which cell you are over, but don't use them to actually position the numeric control.  Use other information you have about the table to determine more precisely where the top left corner of the cell is and place the numeric control there.
Break your event structure into two parts.  Part 1 is the mouse down which determines where to put the numerical control.  The second part should be part of the value change event for the numeric control to update the particular cell in the listbox.  You will need a shift register to remember mouse posistion and cell in order to know which cell to update during the value change event.  Final thing during the value change would be to move the numeric indicator off and then hide it.
Message 8 of 23
(4,729 Views)
Yes I have figured out that it's only the mouseposition you get by the click, and not position of MCL cell.
But  how to get out the position of the MCL cell?
And can you shift the fokus from the MCL cell to the indicator programmally?
Message 9 of 23
(4,713 Views)
Use Active Cell position of MCL
Message 10 of 23
(4,702 Views)
