Strange counter output
Here are the key features of my setup:
  • one analog output: alternate analog value in the while loop
  • two digital outputs:
    • 1st: armed before analog output updates (setup time), duration can be adjusted while loop is running
    • 2nd: armed on request, i.e. on clicking on "Run single pulse" button
      • once armed, remains "ON" for "Pulse duration"  time, then goes "OFF"
      • when it's ON, other activity in the loop is suspended
In the current implementation the behavior is erroneous (purple waveform, CH3)
Where I've been mistaken.
Thnks in advance.
(3,258 Views)
Another bizarrerie - Block Diagram is encircled by red border.
(3,254 Views)
Resolved.
Event loop is armed in 2 cases: when button goes ON-->OFF and vide-versa.
So, introducing of case loop does the job.
Digital_pulse_followed_by_analog_signal_update__2nd_digital_on request (1).png
(3,243 Views)
