If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
03-20-2015 10:18 AM
I have a bunch of .VIs in a library that I got from an SDK, and I have to edit a few of the VI's. I can open the VI and view the block diagram, but when I right-click on things or try to edit it, it doesn't let me. Is it possible to make this VI editable?
Here are some more details on the problem.
In a larger program, I call GetTemperature.vi, but within GetTemperature.vi, there is another VI (U32 To Error Code Enum.vi) that is missing because it previously referred to the 64-bit version of "U32 to Error Code Enum.vi". I need to change it to the 32-bit version. I got the 32-bit version from the SDK, but I just need to replace the 64-bit version with the 32-bit version. So, I open up the block diagram and right-click to hit "replace", but all it gives me as an option is "Breakpoint." I can't change any of the wiring, add or remove any functions, or any other kind of editing.
Thanks for the help!
03-20-2015 10:22 AM
I solved this issue by replacing the whole GetTemperature.vi with one that wasn't messed up, but I'm still interested in how to edit a .vi within a .LLB, and am wondering why I couldn't edit the subVI.
03-20-2015 10:26 AM
03-20-2015 10:38 AM
Probably.
Where would I be able to find out if it's read-only?
03-20-2015 10:55 AM
03-20-2015 10:58 AM
If you mean by right-clicking it, going to "Properties", and checking the box, then no, it isn't read-only
03-20-2015 11:00 AM
Ctrl+I (Vi Properties)
03-20-2015 11:03 AM
In Windows Explorer, right-click on the llb and select Properties. There will be a Read-Only check box. Make sure that is unchecked.
@urlmichael wrote:
Probably.
03-20-2015 11:06 AM
AH! Looks like it is!
Thanks everybody for the help!
