ECG Labview Simulation
Hello, I'm writing because i can't run the ecg simulator that i've downloaded from http://zone.ni.com/devzone/cda/epd/p/id/6189#0requirements
When i try to use it,  it appears a box dialog that says "Find the VI named 'Configure Serial Port.vi'. I tried to open the VISA  Configure Serial Port.vi but i believe that number/type of the inputs and outputs of it, does not match to the expected by the program.
I would be grateful if you could send me some help.
Thanks in advance
Message 1 of 12
(11,764 Views)
Accepted by berper
I have a simulator for ECG. It is not made by me, but NI
How to install
1) quit Labview
2) Unzip to folder ............\National Instruments\LabVIEW 8.6\user.lib\_express (you find it in the program files folder)
3) start Labview
4) Se the picture for help on how to find it
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 2 of 12
(11,746 Views)
Thanks a lot Coq Rouge ! That was exactly what i was looking for! Sorry i didn't show up for so long, but i've been out of town...
Message 3 of 12
(11,634 Views)
how i i want make ecg signal not with ecg simulation toolkit?
Message 4 of 12
(11,459 Views)
What's wrong with using the posted VI? It does not require the full toolkit.
Message 5 of 12
(11,425 Views)
Dear ,
i downloded you VIs but it doesn't work, could you please inform me about the problem.
M. Abdelkader.
Message 6 of 12
(11,002 Views)
which Labview version do you have? If you use Labview 2009 you must use the  ....National Instruments\LabVIEW 2009\user.lib\_express folder If you use a older labview version than 8.6 it will not work unless it is converted to the older version
Message 7 of 12
(10,985 Views)
I used Labview V 8.6 is there any ideas to solve this problem.
Message 8 of 12
(10,963 Views)
You must tell me why it is not working;)
Message 9 of 12
(10,954 Views)
so sorry it just a warrning, thank you for your interest.
it's now working.
Message 10 of 12
(10,947 Views)
