Dynamically write data to an open file in a different sub vi
Is it possible to open a file to write data in one sub vi, pass the ref num to that file to another sub vi and write data to it in append mode ?
Cheers,
Carnot
Message 1 of 9
(3,591 Views)
The simple answer is yes. Why do you ask? Are you having some sort of problem?
Message 2 of 9
(3,586 Views)
Well... why not ?
It seems like the answer is included in the question ? Have you tried ?
You can either let the file open and pass the refnum, or close the file, pass the path and re-open in the sub VI...
Epictetus
Antoine Chalons
Message 3 of 9
(3,583 Views)
I'm opening a spreadsheet in Excel in one sub VI and then writing data to it in another sub
VI using the refnum within a While loop.  At this point I'm getting "An input parameter is
invalid." error.
There's no error when the While loop is not there.  The error is the same if you were to pass the
refnum across two frames of a Flat Sequence.
Cheers.
Message 4 of 9
(3,573 Views)
hi there
please post some code so we can have a look at it.
best regards
chris
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
Message 5 of 9
(3,569 Views)
Here's the code where I'm using two frames (which is equivalent to two sub vis executing one after the other).
Cheers.
Message 6 of 9
(3,566 Views)
hi there
please see the attachment. you have to close the file only ONCE after you are done with it. when closing the file in each cycle you get the error you mentioned after trying to write to the file after it has been closed. please read the comments i added to the vi.
Best regards
chris
Message 7 of 9
(3,563 Views)
Hi Chris,
Thanks for that mod code.  I was closing the file in each iteration of the while loop by including the Close File function within
the sub VI.  That might have been the one causing the prob, yeah?
Regards.
Message 8 of 9
(3,557 Views)
yeah.
Best regards
chris
Message 9 of 9
(3,551 Views)
