wireless communication between labview and MCU
For my project I need to establish a wireless communication between labview 7.0 and MC9S12C (Motorola chip). I wasn't able to find a VI that would help me do it..
(2,511 Views)
Good morning,
I doubt that you will find an existing vi for that.  You will first need to develop the wireless interface from the test PC to the target with the Motorola chip.  If it is to send control data, then the speed can be lower.  Or I should ask at what speed(s) do you need to communicate with the target?
Please provide a bit more explanation about your project so that we can provide more accurate advice.  As for how to create an interface between the PC and the chip, do a search on "Tiny OS".  It is a project from Berkley University.  Have a look at the wireless sensor project.  Once you've established how the wireless communication will take place, then you can start the Labview portion.  Sounds like a fun project.  Let me know how it goes as I am interested in such projects as well.  😄
If you have already defined the wireless interface, then can you describe it?  How does the PC interface with it?  How does the target interface with it?  In other words, what port, bus, socket, do you use for communication?   How does the transmitter work on the target?
Have fun!
JLV
(2,507 Views)
