Dynamically returning to default values
Is there a way in LabVIEW to easily cause a string/int/dbl to return to its default value after an event occurs? I'm attempting to make a UI that goes through the same step many times and it would be easiest to set the entry values back to the default after every iteration.
Thanks.
Using LabVIEW 2009 on Windows Vista
(3,773 Views)
either write to a local after "that event" occurs or you use the method "reinit all to default" for the vi...
(3,761 Views)
If you don't want to reinit ALL controls to their default value, you can do something like that for instance...
(3,753 Views)
Can you please save that VI as an earlier format? I don't believe I have access to version 8.6. Thanks.
(3,741 Views)
@dragonlord...:
Please always note your LabView version, when it's not the newest! The signature is a very good place to do so...
@krs:
Attaching a picture will open the block diagram for users of each LabView version Smiley Wink
(3,734 Views)
Accepted by dragonlordged
LabVIEW 8.0...Otherwise there is a screenshot in zip folder.
Best,
(3,729 Views)
