Download a file from internet programmatically
I think is the file dimension, if I try with small file dimetion all is working fine
Message 11 of 14
(2,184 Views)
@Florian_Hemmelgarn wrote:
At the moment I have the same problem.
I've successfully used data socket to download a picture oder a pdf. But I don't understand what I have to change to download a zip file. Usually when you open a website there is a link which lead to an pop up, asking where you want to store the data.
I've attached some examples. Maybe I just need a working url for the data socket
Please don't hijack someone else's topic to ask a question of your own.  This confuses the original topic and it's difficult to know which replies go to what issue.  Please start a new topic.
Bill
CLD
(Mid-Level minion.)
Message 12 of 14
(2,170 Views)
Hi Paolo1983,
If the URL is HTTP based then you can use the LabVIEW HTTP Client GET VI.
This is an example that does an HTTP GET and saves the result to disk by prompting you to choose where to save the file:
Note: Make sure to set prepend array or string size? to false when writing the binary data to disk
Milan
Message 13 of 14
(2,137 Views)
finlally It is working!!!
Thanks a lot for your help!!
Message 14 of 14
(2,109 Views)
