Download a file from internet programmatically
Hi all,
I need to download a file from internet. I need to make programmaticcaly the action to click on the file link and download the file without the message poupup visualization.
Can you help me.
Message 1 of 14
(6,593 Views)
Hi Paolo,
use DatasocketRead as described in this very old KnowledgeBase entry!
What are you talking about?
Message 2 of 14
(6,585 Views)
When you try to download something from internet, the brawser ask you where you wnat to save the file. I don't wont this, i wont to save the file in a predeterminated path
Message 3 of 14
(6,581 Views)
Hi Paolo,
then do as suggested before.
You will receive a string from DSRead and you can save that string to any file(path) you like to…
Message 4 of 14
(6,576 Views)
Unfortunatelly it is not working,
do you have an example?
Thanks a lot
Message 5 of 14
(6,572 Views)
Hi Paolo,
simplified example:
Message 6 of 14
(6,569 Views)
I try to be more specifics, this is my file url : http://...../Installer_RAT_v3_1_7.zip
I try to do like in your example, but the Data soked read blocks goes in timeout.
Do you know why?
Thanks.
Message 7 of 14
(6,563 Views)
Hi Paolo,
is the file accessible with this URL?
Did you attach the "[text]" suffix as explained in the LabVIEW help for DSRead?
How long does it take to download the file? Does it take longer than the default timeout of DSRead?
Message 8 of 14
(6,546 Views)
At the moment I have the same problem.
I've successfully used data socket to download a picture oder a pdf. But I don't understand what I have to change to download a zip file. Usually when you open a website there is a link which lead to an pop up, asking where you want to store the data.
I've attached some examples. Maybe I just need a working url for the data socket
Message 9 of 14
(6,545 Views)
Hi all,
yes the time is enought but i didn't get the download.
Message 10 of 14
(6,527 Views)
