Downconvert VI Requests
Hi Peter,
it's missing all subVIs and a typedefinition, but here you go...
Message 811 of 1,444
(2,273 Views)
Peter,
Post the link of where you found that so it can be added to the Rube Goldberg thread. It is not an example you want to follow.
Message 812 of 1,444
(2,265 Views)
Bonjour,
d'abord pardon de m'être trompé, (upconvert, downconvert...) c'est la 1ere fois que j'écris sur un forum.
Je voudrais savoir s'il est possible de convertir le vi en pièce jointe(je n'ai pas pu mettre la DLL fournie avec)
qui est en version 8 (je ne sais pas laquelle), dans la version 6I. C'est  un vi pour gérer la carte d'interface I/O
-USB k8055d de Welleman.
Je sais que la version de LABVIEW 6i est un ancêtre, mais j'ai beaucoup travaillé avec, et...je l'ai, en cadeau(chut).
Merci.
Message 813 of 1,444
(2,262 Views)
Could somebody help me to convert those program from 8.6 to 7.1? Thanks!
Message 814 of 1,444
(2,254 Views)
Please help to downconvert the ff: Your help is much appreciated.
Bab
Message 815 of 1,444
(2,237 Views)
Hi Bab,
this thread works best when you say what version you need your VI files in Smiley Wink
Nevertheless: your VIs are already in LV7.0 - do you need them in a much older LV version? Otherwise simply load them with your LV...
Message 816 of 1,444
(2,229 Views)
Could you help me to downconvert mine (see above post)? Thanks.
Message 817 of 1,444
(2,219 Views)
Kudos to whoever downconverts this:  It is in 7.1 but I would like it in 7.0. Found it via the Developer Zone but can't open it...Thanks in advance!!!
Message 818 of 1,444
(2,201 Views)
Hi jrexilius,
here you get a picture of the VI:
When recreating that VI you should change it to use either a state machine or (atleast) use a FOR loop with 2 iterations to replace the flat sequence... Right now you only need two of the local variables, the remaining ones could be replaced by wires!
Message 819 of 1,444
(2,160 Views)
Do you need to see Clock-9 being ON & OFF?
Otherwise, you could further simplify it to :
Message 820 of 1,444
(2,153 Views)
