Downconvert VI Requests
I am using the labview 8.5 user. Earlier i was using the 7.2version labview. I have progamm with the 7.2 version. I want to up convert form labview 7.2 to 8.5 labview.
Could help to conversion.
Prashant
Message 801 of 1,444
(3,366 Views)
Hi Prashant,
I already told you there is no LV7.2! And I also told you you can load LV7.1 VIs in LV8.5 without any problems.
And I surely mentioned you are using the wrong thread, this one is dedicated to "downconversion" - and there is also a thread for upconversion...
Message 802 of 1,444
(3,365 Views)
pashya,
As Gerd has mentionned:
1 - you're in the wrong thread
2 - you do not need to upconvert your code.  LV7.1 will open nicely in LV8.5
But I would like to add that you should avoid using all those Local Variables and all those Globals.
To learn more about LabVIEW, I suggest you try looking at some of these tutorials.
Message 803 of 1,444
(3,353 Views)
Hi Folks,
Please could I ask someone to convert the files from part 2 of Jeff Bohrer's nugget down to V8.5 or lower.
The files can be found in the thread, or in the attached zip file.
Many thanks!
Ian
Message 804 of 1,444
(3,336 Views)
See attached
By the way, there was a missing control..
Message 805 of 1,444
(3,325 Views)
Thanks Ray!
Message 806 of 1,444
(3,322 Views)
Hi
I'm hoping that someone can help me out. I've got a spectrometer that I need to run and the company sent me VI's from LabVIEW 10. I've got version 9 and need them down converted.
Message 807 of 1,444
(3,315 Views)
Hi sthalman,
here it is (I hope I got them all, but I removed the PDF for obvious reasons...)
IMHO that library needs some "finishing" - I wouldn't deliver such VIs to customers...
Message 808 of 1,444
(3,312 Views)
Thanks a ton GerdW,
Much Much Kudos
Message 809 of 1,444
(3,300 Views)
Hi!
Would somebody of you be so kind, and downconvert this VI for me? I'm using LV 8.0
Thank you so much for your help!
Peter
Message 810 of 1,444
(3,284 Views)
