Downconvert VI Requests
Since you said you have LabVIEW 2010 you can do the downconversion yourself. Smiley Wink
File -> Save for Previous.
Message 1121 of 1,444
(1,695 Views)
Could you please help me downconvert these two files from Labview 2009 sp1 to Labview 7.1?
thanks,
Message 1122 of 1,444
(1,678 Views)
I did these small vi's using an eval version 10.0. Our company gave me an official license but it is for version 8.2. Can someone help to downconvert these two vi's from 10.0 to 8.2. I appreciate it.
Message 1123 of 1,444
(1,654 Views)
LabVIEW 8.2 did not have the Fixed-Point datatype so you will need to modify the subVI.
Message 1124 of 1,444
(1,649 Views)
Can anyone please convert this to LabView 8.0. I have the 2009 but I'm getting an error message everytime I try to do it.
Thanks a lot 😉
Message 1125 of 1,444
(1,619 Views)
Thanks a lot 😉
sorry, the file I should have attache instead is the ie below.
apologies!
Message 1126 of 1,444
(1,629 Views)
Thanks.  since there are many VIs in a project, I was looking for a quick way to do that.  NI support staff finally gave me a VI to do it automatically.
cheers
Message 1127 of 1,444
(1,628 Views)
Hi notimperial,
here's your VI in LV8.0.
- The problem with downconverting on your side has to do with the (missing) subVI "VxmDriverLV8.vi" - without it I could downconvert without problems.
- Your VI is written in a bad style. I removed the local variables before conversion.
- The subVI uses the worst connector pattern of all: the 28-connector-monster! Think about grouping inputs in clusters and you will have spare connectors for the error cluster to finally get rid of the sequence structure...
Message 1128 of 1,444
(1,624 Views)
@GerdW wrote:
Hi notimperial,
cheers! I know 😛
Message 1129 of 1,444
(1,623 Views)
I need to convert the attached files from labview 5 to labview 8.6.
Thank you in advance for your help.
Best regards
Amir Fallah
Message 1130 of 1,444
(1,611 Views)
