Downconvert VI Requests
can u please downvert this 2010 examples into a version which can be opened on labview 2009? thanks a lot!!
Message 1111 of 1,444
(1,671 Views)
Hi Batistuta,
here it is...
Message 1112 of 1,444
(1,666 Views)
@Nunzer wrote:
I am after the same files as Aaron... Can anyone downgrade these three VIs from Labview 9.0 to Labview 8.5?
Thank you very much,
- Derrick
Looks like the original request fell through the cracks...
Message 1113 of 1,444
(1,657 Views)
Thank you very much!
Message 1114 of 1,444
(1,654 Views)
Can someone convert this instrument driver library from LV 8.0 to LV 7.1
Message 1115 of 1,444
(1,646 Views)
http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=E3B19B3E90DA659CE034080020E74861
Message 1116 of 1,444
(1,637 Views)
Can someone please be so kind and downgrade the following .vi for me? I downgraded it already as far as I could.
source version: LV 8.0
target version: LV 7.5 and 7.1
Message 1117 of 1,444
(1,631 Views)
There is no LabVIEW 7.5, so I don't know what you are referring to there. Attached is in 7.1.
Overall, the code has some pretty poor programming practices:
  • Main loop needs a small delay else it will spin around at full speed when Start is False, using up ALL cpu time.
  • Unnecessary uses of sequence frames.
  • Lack of error handling/error detection (especially on the GPIB functions).
  • Use of old GPIB functions rather than VISA (which is surprising since you said this was at a higher LabVIEW version to begin with).
  • No icons on subVIs
  • Poor connector terminal choices
Other than that, it's great code! Smiley Very Happy
Message 1118 of 1,444
(1,624 Views)
I could mention several excuses, but I just will take the hit. 😉
Maybe I write a new VI from scratch, since the "code" itself is pretty old and was only copied over and over again into the newer LabVIEW versions (->usage of GPIB functions)
If I do so, you have to downgrade the new VI for me.
Haha, thats what you get by critizicing requesters with poor programming skills...more work. 😛
At least we can use it for now. Thank you!
Message 1119 of 1,444
(1,613 Views)
I have a LV2010 zip, can you help me to convert it to LV8.6 as my colleague only have LV8.6 on his Mac.
many thanks
xiaofeng
Message 1120 of 1,444
(1,596 Views)
