Downconvert VI Requests
Can someone help me down convert an instrument driver
To :     LabVIEW 5.0
Message 861 of 1,444
(1,809 Views)
@smercurio_fc wrote:
Warning: This is poorly written code. The writer must have had a 30" monitor, and assumed that clearly everyone else had one as well. There is also no error handling to speak of.
I am not really surprised. Thank you!
Message 862 of 1,444
(1,804 Views)
 I have a Lab View version 8.5, and used it very well.
 Now, I need to bring a code made in version 8.6, and my 8.5 version refused to open the 8.6 code.
 Could anyone convert it?
Message 863 of 1,444
(1,773 Views)
Downconvert 8.6 ==> 8.5
Message 864 of 1,444
(1,772 Views)
Find attached the VIs in 8.5... I would suggest you to minimize the usage to Sequence Structures as they reduce the efficiency of the code.
Nitzz
(Kudos are always WelcomeSmiley Wink)
Message 865 of 1,444
(1,763 Views)
Hello again,
I would like to have this vi converted from v10.0 to v9.0, please?
Thank you very much!
Message 866 of 1,444
(1,757 Views)
Hi rmpflr,
Here it is in 9.0
Nitzz
Message 867 of 1,444
(1,755 Views)
To :     LabVIEW 5.0
You will have some work cut out for you since some things that are being used don't exist in LabVIEW 5.
Message 868 of 1,444
(1,738 Views)
from labview 10 to labview 9 please 🙂
Message 869 of 1,444
(1,733 Views)
Hi coolhand,
here's your VI in LV2009 (I replaced two ExpressVIs by generic LV functions, I really think a simple multiplication is more easy to understand than a Calculator ExpressVI...)
Btw. there are two missing subVIs!
Message 870 of 1,444
(1,731 Views)
